I have an '86 Four Winns 190 Horizon with a 305 5.0 L engine and a stock Quadra Jet 4 barrel carb. The carb adjustment screw is stuck and the carb is old so I want to replace it and want to know what carb I should put in. I was thinking of an edelbrok 600 cfm. Can I go larger or is there a better carb I should look at?
I was also thinking of replacing the distributor points with an electronic ignition. Is this a good idea and if so which would you suggest?
I'm trying to get a little more power and a better running boat without shortening the engine life. Any help or suggestions would be greatly appreciated.
Thanks everyone!
Thanks everyone!
