Carburetor not working 2006 Johnson 3.5hp
yeter
The engine has been sitting in my shed for a couple of years and I guess something is stuck in the carburetor because the engine isn't getting any fuel. Is there something simple to try before taking it to a repair shop or buying a carburetor rebuild kit. I checked to make sure fuel was getting to the carburetor.
Thanks,
Yeter
Daviet
Re: Carburetor not working 2006 Johnson 3.5hp
Does any fuel come out of the carb bowl when you remove the drain screw? It sounds like it is time to overhaul the carb.
yeter
Yes. Fuel does come out of the carb bowl when the drain screw is removed
Daviet
It sounds like it's time to overhaul the carb.
Monte1961
Here is an exploded view of your carburetor. A few things you want to keep an eye on. Item #s 8,10,12,16,18,21. Post back results.
yeter
I took it apart, cleaned it, put it back together and ... it runs. Thanks Monte.
Dkwazneski
Johnson 3.5 hp
Can anyone tell me the factory setting for the Carb. adjustment? How many turns out.
hidef
Start at 1 1/4
