So after fixing my head gasket on my 1990 90hp I noticed a lot of fuel coming out of the overflow on the lower carb. Took it all back apart and all I could see is one of the floats was adjusted different from the others so while it was apart I ordered new needles and gaskets for the bowl. The floats are ok in they float in water no bubbles when submerged so I think that is ok but should they all be they same? From left to right you can see the lower, middle and top carb. Now I will admit I did screw up and not keep the parts With their respective carbs so the bowls may be on different carbs but should I adjust the high one on the right to be the same as the other 2?
