Carbureted 2 stroke fuel additives?
Cookingkahle
Anyone have suggestions on a good 2 stroke fuel stabilizer/additive, good running 1983 70 hp mercury
Chris1956
What do you want the additive to do? I presume it is more than just keep the gasoline fresh?
Cookingkahle
Thanks Scott danforth not the greatest but of information and I thought it was obvious that I was not talking about oil.
if you're looking for an additive to increase the life of the fuel. the 2-stroke oil does that - it adds the carbon backbone molecules needed for the fuel to not break down as quickly. however fuel will still go bad eventually
if your looking for an additive to lubricate the engine, the 2-stroke oil does that.
if you are looking for an additive that does some miracle thing, it doesn't exist.
if you are looking for an additive that cleans your fuel system, it doesn't exist
there is no mechanic in a can
therefore the only and I repeat the only additive you need for a pre-mix 2-stroke fuel is the 2-stroke oil.
Sea Rider
And run fresh fuel on each outing with no product whatsoever added to the fuel besides 2 strokes oil...
Happy Boating
Cookingkahle
Thanks guys that's a much better explanation . I know theres much controversy over this topic and I just want the best life for my older merc...
