carburator problem loading up with gas
royalregal
My carburator over loads up with gas. Worked great last year.
Started it up this year and carb loaded up with gas. Quadrajet carb
I took it off a just had it professionally rebuild because it was loading up with gas. I put carb back on started right up then loaded up with gas again.
Then I tried to restart and it seamed like it wasn't getting any gas.
After a few minutes I started it again and it loaded up with gas again.
Do any of you know what might clause something like that?
keep in mind a well respected carburator shop just rebuild carburator yesterday. so I don't think it could be the float
Re: carburator problem loading up with gas
Ayuh,... Bad floats or Badly adjusted floats...
6meter
The needle and seat aren't seating. Cheap carb kits have bad needle and seats from my experience. Redo the carb with a Delco kit. Seen it to often.
sethjon
The floats are sticking. Maye due to sludge or adj. If old then a maybe, but doubtful a rebuild is in order.
John_S
It will also happen when a fuel pump is putting out too much pressure. This happened to my 5.7L and had to make up some fuel lines and a Tee just to hook a gauge up to verify. The fuel pump quit entirely within the next season.
royalregal
yep it was the fuel pimp ehanol gas had the fuel pump pushing 8 psi i put a manual regulator and gauge in the fuel line ajusted it to 4.5 psi work great but i guess i will have to put new fuel pump soon so imported _John_S. YOU WERE 100% correct.
THNK YOU
