Carbuerator cough?..
72Stinger
When I start the boat I can hear a distinctive sound that sounds like "air leak in a can", actually you can tell whenever the piston is in the up position. Is this a basic carb adjustment or a minor carb rebuild or is it something big?
TwoBallScrewBall
Re: Carbuerator cough?..
Might be an exhaust leak, check your manifold bolts for tightness. An exhaust leak will pulse with the engine rpm, and sound like anything from a tick-tick-tick to a psst-psst-psst or worse depending on how loose the manifold is or how blown the gasket is. And chances are if you have a leak you will need a new gasket.
deputydawg
Does this sound like it is coming from the carb? If it does, do a compression test. possible it is a bad intake valve, or could be an intake valve stuck open.
72Stinger
Well you just described what it is doing and I did put a exhaust and head gasket on but it has been since April. Since it is old, some bolts are getting lose, maybe I didn't torque it properly, I need to rebuild the carbs anyway, thanks for the input! You helped!
