Carbs.
HAS
I have the 3 carbs.off an older inline 6, they are MERCARBS NO.1395-5677
WMK-23,NO.1,2&3. Free to anyone that can use them. All I had was the block,it had a distributor and a 2&7/8th
bore, the no.6 piston was frozen in the cylinder. I took the crank and the other
5 pistons out, there are no scratchs on any of the pistons or on the cylinder
walls.The no6 throw on the crank is .006 under size, the rest of the crank. and bearings looked good. I would like to know if the
block and crank could be repaired?? The owner took everything but the
carbs. to the junk yard and got $25.00 for it. I think that was a big mistake.
The carbs. need to be overhauled. If anyone needs them, they are free.
Just let me know how to contact you.
HAS
