Re: Carbs versus EFI
Hi,<br />Probably a good point, but I would personally consider EFI safe (safer?) compared to carburators. Have a look at the trend: it is towards EFI, more and more models and for smaller and smaller outboards. Example: Yamaha has for 2005 released many "old" models now with EFI instead of carburators (F50, F60, F75, F90).<br />You do not read much here in the forums that EFI has been a trouble. On the other hand EFI outboards has not been on the market for so many years so... In 10 years maybe a forum like this is full of posts that relates to trouble with the EFI (but I hope not).<br />I had a carburated outboard before but use now EFI outboard. I have full confidence in EFI so far. These days I do not make any "service" on my outboard myself (because it is still under warranty, in 4 more years) and service is not that expensive after all for a small-mid size outboard (I have a 115 hp outboard). I can not do anything about the EFI system myself if any trouble with that. I trust my service center to sort out any problem with that.<br />If You have time and like to do service Yourself on your outboard a carburated outboard maybe is better then since You then at least can (if you want) make some service to the carburators.<br /><br />I do not know how what the weaker spots are in an EFI system but I guess the electronics is one of them and if that fail it could mean - a stop. A carburated outboard may take you home to harbor if any minor fault in carburator(s). But there are electronic "boxes" in carburated outboards also (CDI box etc).<br />In my opinion it seems the outboards gets safer and safer to use in terms of hours they run without any trouble and trend is towards EFI.
