I was on the water and it wouldn't run faster than 8 MPH at first....but periodically it would climb then get to about 35 MPH. If you left it alone you would stay at 35, if you backed off....back to riding around at 8 MPH. I got the rebuild kit and did that, I was surprised to see that the floats are not included in these kits as that's what I suspected. But the floats look fine and have no fluid inside of them, am I looking in the wrong place? The boat started rite up and ran full speed in the yard first try...then came the gas leakage...lol...back to no start.
I read someone with similar problem suspecting the Fuel Pump, could that be it? Because it seems a little unlikely that ALL my floats are bad...the fuel doesn't only pour out the front, but also out the little breather/overflow holes (whichever, idk) on each side of each carb. But I figure if the pump was bad it would not pump sufficient fuel, not too much fuel..right?
Thank you guys for any suggestions
(1989) Mercury Force Outboard 85 H.P.
Serial : 858F9C
Serial : 858F9C
