Is it normal to have carbon build-up in the lower unit? I had the motor running on the muffs and noticed leakage from one of the bolts connecting the lower unit, so I decided to pull it off and found somewhat heavy buildup on everything, as well as a bit of water/oil/gas/carbon muck leaking out. <br />Also, is it normal to have water in the lower?? I have some coming out of both the pee hole (good), and the exhaust (bad?).
