Carbeurator Cleaner
goingagain
Re: Carbeurator Cleaner
I use a product called Sea Foam, u can get it at most auto stores. it is good for storage and clearing carbs.
john
Faztbullet
If carb system is working ok, Seafoam or other products will work. If you have jets or needles stuck all the additives in the world will not fix them. A jet or passage must have some flow thru it for additive to work. Also if operating engine with bad fuel system you run risk of damaging it .
