I have a mid 80,s 35hp mercury. The problem that we are having is in the fuel delivery. The motor runs fine at 3,000 rpm,s anything lower than that the motor doesn't want to rununless you choke it but on the other hand you can,t keep it choched or it will die. So you push the choke let off the choke and keep doing this repeatedly to keep the motor running. We have torn the carbs apart to clean them several times did not work. We dipped the carbs and rebuilt them twice seems to still not work. I have the secondary lever and the primary lever for the float where they are supposed to be set and this motor still doesn't want to run without choking. We have noticed if you let the motor idle down that it starts pooring gas out of the front of the carb. My boss seems to think that the carb is bad all together and i'm starting to think the same thing. I need some opions if you guys can help before I tackle this motor again.<br /><br />Thanks <br />Nick <br />Prop Shop Marine<br /><br />------------------
