Carb rebuild
werdnlr
Hello all, well I just completed my carb rebuild. Took about 3 hours total. Motor fired right up and idled great. Is there any way of putting a load on it without taking it to the lake?
Thanks for all the advice! Made the job easier and less daunting. Also helps to have the right parts, tools and manual
tashasdaddy
Re: Carb rebuild
take it to the water. you need to set the idle high, if on muffs, as there is no backpressure on exhaust, then refine idle in the water and in gear.
