MichaelP
- Apr 26, 2010
- 1,190
I just rebuilt my carbs and before I put them back on the engine I have a concern about the jet adjustment. All the jets in both carbs were screwed in tight and after cleaning them I put them back the same way. Is this right? Not having done a carb rebuild before I'm hesitant about this. Can it be as easy as set and forget? I'd hate to have to pull the carbs off again to get to the ones inside the bowl. The high speed jets are meant to be adjusted and are easy to get to. All readings here say to back them off a number of turns??????
This is a new to me motor and I've never herd it running. I had it winterized and looked over by a reputible nearby merc dealer and they simply said the carbs need to be cleaned. Man were they right, the inside wasn't varnished but there was fine debris in the bowl and all the jets we almost completely clogged. But it ran with the jets completely seated.
