Re: carb rebuild problem
First off, why did you rebuild the carb? Was there a problem with how the boat was running? Could be the problem wasn't the carb.
Sounds to me like fuel starvation, although there are other things that could cause the same problem. Did you replace your filters? Is your gas good? Have you tried running it off of a separate tank with gas that you know is good?
