series2000
- Sep 7, 2004
- 12
Pick up an '85 Evinrude 40 (cheap) that sat two years but seems to run good. When I spray de-carb into the bottom carb it sputters and smokes like it's supposed to. But when I spray into the top carb the engine speeds up. It is definitely running on both cylinders. I doubt if this is normal. Should I do a carb rebuild or do you think running a strong mix of fuel injection cleaner or gumout in the fuel would get the job done?
