Re: carb. rebuild NEED HELP
I have the Seloc manual for that age and size of engine as I am going to be doing similar work on my '84 70 because it has been sitting a long time. I had to read that section several times before I understood it myself, but your carb is in there. There is 4 types of carbs type 1,2.... ect. In the back of the manual your year and size of engine will be listed along with a lot of other data, 1 piece of data will be which type of carb your engine has. My '84 is the type III and I assume yours is too. The manual doesn't spend much time on the type III carb because it is very similar to the type II carb. So basically you are mostly following the type II carb instructions. I think that's how it went, it was a few weeks ago that I read it.<br /><br />A good tip in the manual was to take digital or Polaroid pics as you go along, then you can see how it was before you disassembled it. I will be taking the pics!<br /><br />Jeff
