carb question
01gp1200r
is there anything i can spray threw the fuel line (from the tank side)that would help clean out the carbs, without taking half the ski apart? like c-foam.. or carb cleaner. or maf cleaner.. I know never to use brake cleaner...
01gp1200r
Re: carb question
when i pulled the plugs they had like a jelly between the tips. I just figured maybe thwe carb were the same way, and i could just blow them out.
bigdaddypt
Re: carb question
if that's the case, you have to remove them, rebuild them with an OEM carb kit, and spray carb cleaner and pressurized air through all the small holes, jets, etc to get it cleaned. PWC carbs are too small for any of that stuff to have an effect on.
01gp1200r
Re: carb question
damn.. ok. Just dont have 150 bucks right now for the rebuild kits.
01gp1200r
Re: carb question
Is there a easy way to pull the carbs?? it looks like i have to damn near pull the motor out.. I cant see a good way to get to the bottom nuts
01gp1200r
Re: carb question
very cool very cool.. thanks bro.. Hey man do you think I'f i pm'd you my number you could give me a call and kinda help me out please?
