04Bayliner
- Aug 17, 2018
- 4
2004 Bayliner 175 with a 3.0 Mercruiser. Carb is a 2 Burrell Mercruiser not a Rochester. Initial problem was run-on and bogging down under acceleration. Initially verified engine timing was correct and rebuilt carb. Used a kit from MikesCarburetor.com, soaked everything in B-12 Chem tool for about 45 minutes, assembled with new parts and verified all adjustments with spec sheet. Engine cranks easily and runs great. It idles well and accelerated without bogging down or stumbling.
Now for the problem. There is a loud hissing coming from around the idle enrichment screw. I cranked the engine and allowed it to run for a second, then sprayed WD-40 all over the area. Spraying it produced no change in engine sound or speed. It runs too good to have a large vacuum leak, but still hisses loudly. This particular model does not have the TKS system on it. Enrichment screw is set about 2 1/8 out from seated. Do you have any suggestions?
