trackerdave
- Jun 30, 2005
- 37
79'Johnson 55hp not running at full capacity:<br />This engine (for party barge) had not been run for two years when I started working with it. I can get it to start and to idle (fairly well). It runs well in reverse and revs up nicely when warm up lever is engaged. It will run forward but when the throttle is fully engaged the engine is only running at about 1/4 of previous full speed. When I back off of the throttle a hair it increases speed a little bit but still only running at about 1/3 of full. I've tweaked with the throttle cable, replaced fuel and line, with no luck. Carb problem? any advice is appreciated.<br /><br />thanks.
