Carb kit for 1996 3.0 LS
Jefferyg63
Hello, First post for me. I just bought a 96 1750 LS 3.0 that is a nice clean boat, but has a couple small issues. Boat will start fine at the lake on first try. After running across the lake, we shut down for several minutes, and it will not start back up unless you take out of gear and advance throttle about 2/3 open. A that point , I can smell fuel slightly. Also will diesel on occasion at shutdown. It runs great other than that. I'm figuring it needs carb rebuild, so I call I- boats. They say they don't have it and to call Siera directly for a part #. I call them and they say there is no kit for my carb. And that it must be ordered piece by piece. What do you think? I'm sure there has to be a kit somewhere.
Thanks in advance.
Jeff
Don S
Re: Carb kit for 1996 3.0 LS
Do you have a Merc serial number for your engine handy? Mercruiser has kits, you don't have to order each piece individually.
Jefferyg63
I have not taken mine off yet. Does mine have the 90 degree bend in the accelerator pump?
fat fanny
Check these guys out aftermarketmarine.com they sell a universal kit for both mercarbs and rochesters what type do you have? does it have one Idle adjustment screw or two? eighter way they can hook you up for under $40.00. Good luck and post back
Jefferyg63
Gonna check them out. Thanks
nola mike
Hello, After running across the lake, we shut down for several minutes, and it will not start back up unless you take out of gear and advance throttle about 2/3 open...Also will diesel on occasion at shutdown.
Jeff
Sounds about normal to me...2/3 open might be a little much, but dieseling after hard runs isn't unusual if you don't let it cool down before shutdowns.
