carb issues
mikieg
so this motor i got with my boat, the one that was hanging by its lock and cable in the water for a couple years, runs. it wont idle. it will run wide open except it spews gas out of the two holes on the top sided of the carb as it is running. i believe that it is flooding. then it will only restart if i drain the float bowl. is this a float problem? what should i do next?
pvanv
Re: carb issues
What is your make/model/serial? Yes, sounds like time to go through the carb.
mikieg
Re: carb issues
i have another thread titled "what is it?" this thread has all the numbers i have found so far. love it if you could help me identify it!
