hey...
I rebuilt my carbs, and after had no idle...runs fine at speed...
if I lift the lever enough to keep it idling, and turn the idle mixture screw closed on the bottom carb, the engine dies...
if I do the same on the top carb, no change occurs...
I assume this means the upper carb is supplying no fuel at idle...
I have looked at this several times now, and am stumped...
I can see thru the hole when disassembled, so I know its clear....
what else controls idle fuel?
or in other words, help!
any input is as always, welcome...thanks.
