I have a '94 Kawasaki 750XiSS. I've cleaned the Keihin carbs and installed new carb kits. The motor will start if I close the choke and open the throttle until I see fuel coming out uf the holes in the choke. Once I see this I turn the choke off and the motor will run until the fuel that was built up in the carbs is used up. There seems to be no vacuum without the choke. I'm at a loss at this point. I noticed that there is a extra pump on the carbs but I can not locate a pump kit on the OEM diagrams. Any and all help would be greatly appreciated.
