1984 johnson 70 hp. from the start of the season the motor has been giving me a hard time starting, some days are worse than others but once running it is fine. this wknd it wouldnt start at all after sitting out in the river and had to get towed in. i'v changed the fuel line with no change at all, tanks are vented properly and all tanks have the issue so it's not the tanks. since i've owned it (4years) it has always given a problem on holeshot, it will stall unless i push the choke in before it has a chance to stall and then goes. end of last season i rebuilt all the carbs and no change with this problem. if i spray pre mix in the top carb when it is getting ready to stall it takes off, the rest bog when sprayed, so obviously there is a problem w/ the top carb. any help would be great as i am getting aggrivated
