I have a 1988 60hp johnson and needs some carbs for it. I found some on a 1990 60hp johnson, will they fit on mine? I looked up and they have different part numbers.
They had a couple changes around those yearssome had a fixed low speed jet and others had an adjustable,I ALMOST positive you can use them.If it were me.i would,especially if it was for free or cheap.I suggest you change as a set though,especially if its a differance in the adjustable low speed
For 50 bucks it is absolutely worth a try - it is very likely they will work. The 90 carbs will have the adjustable idle mixture, but that's not a problem.
Picky picky Tash,heres what BRP calls it,(0335014 NEEDLE VALVE, Slow speed ).I kinda thought slow speed was like an idle,but,I guess Im wrong.ANYWAY,get er done.
