I have an '78 Mercury 800 80hp in-line 4 cyl, s/n 5004055 which has recently been flooding out intermitently every couple of days or so. Several times I have had to remove the plugs and dry 'em off, remove the dual carbs, drain and clean out in order to start engine. Once started the engine seems to purr at idle and runs like a top at WOT. I thought my starting problem was gone after these results but then it came back next day. The carbs seems flooded as there's gas around the throats and all smells gassey. Could my float be set too high and/or needle 'n' seat need not working. I rebuilt both carbs last fall and carefully adjusted the height of the float to specs. I haven't noticed any foreign material inside the carb or joints/hinges sticking. Both needles seems to move up n down easy, too. The electric choke seems to turn on/off okay. When I attempt to start I always connect the line and make sure to prime the bulb to firmness.<br />Any help would be appreciated.
