I have I/O 3.0L merc motor. When I run the engine hard ie towing water skiers etc and then turn off engine, upon restarting the carb seems to be in a flood mode. To start I need to advance the throttle to allow more air in the carb before I turn the ignition. On occassion, I have check to see if the choke valve is stuck and it doesn't appear to be. Twice, I have taken the boat in to marine repair shop where they ran the engine until hot trying to reproduce the problem unsuccessfully. Both times I was told that the carb is working fine. Any thoughts as to what else I should be looking at?
