I have a 1984 Johnson 150 GT with the VRO disabled. My question is can the metal on the carb float become fatiged so that it doesn't remain where it should? Because while running it on the water hose I noticed fuel dripping out from the bottom of the carbs. It was coming from the middle one, I took it off and checked to see if anything was clogged. I looked at the float and it seemed too far down so I adjusted it put it back together and no more dripping. Then about a week later, after about 4-5 outings I had to repeat the same process as above. It's been about a week and so far no fuel leak but I'm keeping a close look to make sure. Thanks for the insight.
