Re: carb floats cracked
Would still run, only just and not very well at all. Cracks in the float allows fuel to enter, making the float heavy and unable to float. If the float does not float ( I like that!! sounds cool) the fuel supply is not cut when the float chamber is full. This could lead to flooding and leaking.<br /><br />If the floats are cracked, it is almost certain that other carb seals, gaskets, jets etc also need attention. That would be more likely the cause of your poor/non running condition. Rebuild kits are relatively cheap.<br /><br />Good luck.
