carb change
yankneck
If I put a 30 horse carbs on my 25 horse motor, will I get increase in hp. power heads apear to be same, same bore, same everything. In fact the shop mannual I have lists all specks for the two motors as the same. Oh yeah 93 Suki DT25, want to put DT30 carbs on it. Thanks
f_inscreenname
Re: carb change
Think you would have better luck finding a answer in the outboard section. You,you....outboarder. Just kidding,good luck.<br />WOW....300 I spend to much time here.
NathanY
Re: carb change
I dont have much experience in that field on outboards, but on a 2 stroke dirtbike, if you want more power, you have to not only change the carb, but you also have to change the reeds and the main jet. Hope this helps.
