Carb butterflies in shut position
Waltomeal
I have 1983 Johnson 115 that I have been trying to get running smoothly., I removed the cover to the carbs and noticed the butterflies are in the closed position, when I push the electric choke in the key with the key in the on position I hear a click but there's no movement of the butterflies, they aren't frozen but don't open, they stay shut, any suggestions to correct this would be greatly appreciated.
harringtondav
Most carb chokes stay mostly closed until the electric or manifold heater warms up the choke spring allowing the choke to open. But most carbs have an adjustment to allow a specified amount of choke plate opening during cold start. This could be out of adjustment. 1/8" - 3/16" comes to mind as common.
Most carbs also have a linkage to open a cold choke while the throttle linkages open. Check this out also.
GA_Boater
Welcome aboard, Walt.
This is an outboard and I think it uses a primer solenoid, the clicking you hear, and you are seeing the throttle butterfly. So this is normal and the butterfly only moves with the throttle lever.
A choke and a primer have the same purpose - To richen the fuel mix on start up.. The primer allows extra fuel to be squirted into the carbs and the choke plate reduces combustion air. Both ways cause a higher fuel to oxygen ratio for easier cold starting.
By running smoothly, what is the motor doing or not doing? Have you checked compression and spark on each cylinder?
There are no choke flappers !!-----It uses an electric primer valve.------Push the key in while cranking it over.----A motor in good condition will start instantly.
