Carb Blowback
cuckoo
Getting some blowback through the bottom carb on a 99 model 60hp 2 stroker. Fuel puddles up at idle and at higher RPM's a nice fog emits outward from the throat. Pulled the carb and gave it a good cleanup job which it didn't need. This engine (boat) has sat for the last five years and just had the carbs all cleaned up about 50 hours ago, if that long. I seem to think a broken reed for that cylinder may be the problem. Are these located behind the plate (intake) that the carbs are bolted to?
diaric
Re: Carb Blowback
sounds like a reed, should suck, not blow. the scematic i looked at shows the reeds under the carbs in the intake manifold.
cuckoo
Re: Carb Blowback
Thanks for the info. Finally found the schematics online and they look fairly simple to get to...
jimmy57
Re: Carb Blowback
had the same issue with my old 650 the man said the reeds were shot but engine had set for a few years torn it down and just what i had thought they were nothing more then gummed up and were just fine put in new anuway while i was in there but they were just dirty from sitting
