hello ! i have a 2000 yamaha cmh 2stroke as a kicker motor and recently gave it a carb cleaning by completely dismantling the carb , ultrasonic cleaning of all jets and all carb parts .
the engine starts and runs great but i,m not sure if the idle air screw is set correct .
- is there a procedure or manual for adjusting the carb ?
-bu default the throttle linkage was set that the throttle body started to close again opposite direction when full throttle on the tiller which sounds wrong to me . now i adjusted it on the linkage that the throttle body is fully open in 90 deg position. that is correct now or not ?
best regards and thanks for any hints !
