carb adjust on 1980 1/2 80 HP merc
bigheaded5
I acquired a 1980 80HP merc, and have done some work to it (water pump, head gasket) and it has good compression. I took the carbs off and cleaned them and realized the low speed needles were way different on each carb as far as turns out. One was 2 1/2 turns out and the other was 1/4 turn out.... The previous owner said he tried to adjust them ...scary having met the guy.
My question is...whats a good starting point for the low speed screws?
bigheaded5
Re: carb adjust on 1980 1/2 80 HP merc
yea, thanks for all your help... 83 views and NO help...wow
FYI I found the info I was looking for...1 1/2 turns out is the correct starting point.... ;)
Chris1956
Yes, you have the correct starting point for idle mixture adjustment. BTW- the final settings will likely bedifferent, although likely by an 1/8 of a turn or so.
ABTW - that motor does not have a head gasket.
bigheaded5
Yes.... for those familair with the motor, I figured when i said 'head gasket" they would know what i was talking about...It was a lot to type WATER JACKET COVER GASKET ;)
