car towing capibillities question
brother chris
Do you think that a 1992 chrysler lebaron (not sure if it is a 4 or 6cyl) would be able to tow my boat. My boat is 16' long and the trailer and boat weigh about 1200 lbs.
My mom is giving me her car, but I want to be sure it will tow my boat.
The car has a class 2 trailer hitch on it already.
Any kind of input would be appreciated.
Cheers,
B.C.
JB
Re: car towing capibillities question
It will probably work, Chris.
Have a Chrysler Tech look at the ID plate and tell you what it can safely tow.
brother chris
Thanks JB, good idea.
I would only really be concerned if it was a 4 cyl. That weight would be hard on the tranny after a while.
Bob_VT
Chris - don't forget the brakes. A fresh set of pads are cheap and good insurance.
D
DJ
Guest
If your boat is truly 1200 pounds, you should be OK. I'll bet it weighs more than that.
POINTER94
Chris, I had a 90 LeBaron with the 4 cylinder and used it a couple of times to pull a pop up camper. It worked fine. Not exactly a speed demon, but it wasn't one to start with.
Watch the head gaskets on that 4 if that is what you have.
harkawy
I have a 17' Aluminum bass boat that I pull with my '04 CR-V. I have no problems going up hill or retrieving from the water.
D
DJ
Guest
What does that have to do with a 1992 Chrysler?
The Chrysler tow rating is 1000 pounds-MAX. The engine/trans. are not not the issues, the body and brakes are.
Daddy O
Most front wheel drive passenger cars are 1000 lbs. towing cap. Usually pulling is not the problem, but stopping is the problem.
Drrockter
I would be wary of that class 2 hitch. Most third party installers don't care what they put on a vehicle.
whywhyzed
Banned
any car can tow 1,000 lbs. 1,200 behind that car will be no problem if you take it easy
