Cap assembly, oil reservoir
kirmy22
A friend of mine has a mercury 150 serial no OD232575 and her cap on her oil injection system is cracked ,I was trying to find her one here on iboats but I cant locate it under anything i search for. It has two wires going through it and a float underneath it, if anyone could point me in the right direction that would be great, also cant seem to find what year the engine is she thought it was a 97. Thanks
Richard45
Re: Cap assembly, oil reservoir
mercury parts by serial number (search)
or you could use this stuff works great
FlexSet is a non-sagging, non-shrinking, permanently flexible epoxy adhesive. Sandable, paintable and chemical resistant, this flexible epoxy adhesive resists vibration and bending failures. It is an excellent product for bonding, repairing and adhering many difficult to adhere to plastics such as Polyethylene (Starboard, Marine Lumber) PVC, ABS, Lexan, Hypalon, etc. Repairs to fiberglass, wood and metals are also accomplished with FlexSet. FlexSet is packaged in a convenient 30g dispenser assuring a proper mixing ratio.
