I have a 92 115hp johnson outboard that starts and runs fine, but when i try to turn off the engine it keeps running. The kill switch also will not stop the engine. When the key is turned off all gages turn off. I have checked the switch with an ohm meter and as far as i can tell the switch is working as it should. any ideas on where to look next or what to check?<br />Thanks guys for any help that you can give.
