I have a '87 bayliner capri wiht a penta 2.3 and a penta 275 outdrive. My trim motor generally works fine (trims up with i tell it to and down when I tell it to) when im ideling/trailered or at low speed. As I don't have a trim gauge I've timed it to take aprox 10 sec to articulate from full in to full out positions. When I'm running on plane however, the outdrive doesn't trim out at all. I can hold the switch for as long as I want to (30, 40 sec, whatever) and if i then cut the engine and go check, it hasn't moved from full in. Does this make any sense?
