cant take off trim tab
james_dorion
trying to get the trim tab off of a pre alpha mercruiser outdrive. The bolt appears stripped. what is a sure fire method to get that off with tools at home.
oldjeep
Re: cant take off trim tab
What kind of wrench are you using? With the Alphas, some of them are allen head bolts and some are 3/8" bolts. You should be able to see it by looking down the hole with a flashlight. If it really is stripped then I've had decent luck with Irwin bolt extractor sockets if you can fit it through the hole.
Don S
If it's a stripped out allen head, either drill it out with a bit that just fits inside the stripped out head, or if a zinc anode, just melt it off with a torch. Zinc has a very low melting temp.
