I just bought a 1968 Wellcraft 19' with a 1984 AQ125a mated to a 280 outdrive. It had a few minor problems that pervented it from starting but I've sorted those out and now it starts and runs fine. I've still got the heat exchanger and associated plumbing off while I wait for a new timing belt tensioner to arrive.
In the mean time I'm trying to figure out why I can't shift from the remote control. I'm pretty sure that it was working when I first brought it home. I removed the link from the shift on the outdrive and can flick the drive from F-N-R no problem. The remote handle moves fine for throttle only but when the shift is engaged it seems to be locked. When I say locked I mean it moves about a 1/4" but then it seems to be held by something mechanical, as opposed to a dry of frozen cable, the feeling of which I am familiar with. Is there some kind of mechanical interlock tied into the trim? BTW, the drive has hydraulic trim as oppsed to the electro-mechanical tilt only.
Also, the drive responds to the trim switch the opposite of what you would expect, i.e. switch up equals drive down. I'm guessing it's just a wire swap somewhere that needs to be done. I have the Seloc manual but the wiring schematic has me perplexed. Can someone clue me in as to where I should be looking?
Thanks in Advance,
Steve P.
Thanks in Advance,
Steve P.
