Can't Shift Gears when in the Water, Help!!!
liboatguy
Here is the situation, when the boat is running on land, with the ears on of course, it shifts no problem, when I’m in the water, once in gear I can’t get it back out, I have to shut off the motor to do so. Doesn’t matter, forward or reverse. I rewired the “Shift Cut-Off Switch” and when I push the arm in it kills the motor so I know that piece is good. Did I mention that the tilt doesn’t work!!!!! I blew a hose, which on the older Cruisers (1973) models; you can’t get a wrench on the line that goes out the bottom of the stern. I need to reroute the new custom hoses thru the transom and figure the rest out (any help with that one would be most appreciated also!!!), so I am wondering that since the drive is not locked down, she flies up in reverse, if this could cause geometry problem, thus a alignment problem somewhere. The drive is an old style MR-Alpha 225. Thanks for any insight!!!!
Rhadley
Re: Can't Shift Gears when in the Water, Help!!!
The shift kill switch only works in the water where there is back pressure from the prop. I suspect that it is not adjusted properly.
The Hyd. Manifold unbolts from Under the transom shield, Outside the boat, + you can then change them out........<br />I'm with Rhadley on your Shifting Problem......<br />You Should have a Reverse Lock Valve mounted at the back of the motor.....<br />You need to get this Fixed, While you Still Have U-joints.........<br /><br />1973 would be a Mod. 1, or "R" drive.......
Chris1956
To elaborate on what Rhadley said. The resistance on the shift cable caused by the transmission (gear) load actuates the cut out switch. I suspect your cut out switch doesn't move easily enough to function properly. Lubricate the plastic "triangle",and tighten until it is just snug, but not tight.
