I replaced the raw water pump on my 85 Merc Alpha 1 (gen 1). After putting the lower unit back, I had trouble with shifing. First time, it wouldn't shift into reverse at the control box, like something is stuck. So I dropped the lower unit and tried again; this time, it would shift smoothly from forward to neutral to reverse at the control box, but the prop stays in forward (prop rotates freely clockwise, locks counter-clockwise) no matter where the control box is, F N or R. I tried gearbox install procedure a few more times and would end up in one of these two situations.<br /><br />I have the manual, and I've been reading all the threads about installing the gearbox, I was careful to follow the instructions; and I'm not sure what i did wrong. While the lower unit is off, I checked the shifting by rotating the shift shaft and the prop locks properly. <br /><br />Any advice would be greatly appreciated as I already struggled with this thing for two days now. Thanks.<br /><br />tuan
