1977 IMP- 5.7 GM 4bbl 280 OD w. PT. In my quest to replace the gimble bearing, its my understanding that the od will have to be removed. The book states to remove the bolt holding pivot pin in place, attach a 5/16 bolt into the pre-tapped pivot pin and pull right out with a slide hammer. I have done this but the pins will not com out. it will move about 1cm each way but that is it. I have a heavy slide hammer and have put quite a bit into the taps. It almost seems as if something is still holding it in place. Any suggestions. Also does anyone know where I could find a parts layout that shows the gimbal(drive shaft bearing) and the od?
