ctswf
- Aug 7, 2012
- 424
My friend started removing his lower unit and can't get it off.
Johnson outboard 225hp 1994
I stopped by to help, it pulls all the way out, then gets stuck at the very last point. It seems like the shift rod is what is hitting
I was not there when he started, I believe he tried spinning the shift rod in an attempt to get it out. I spun the shift rod a little back and forth but didnt want to get anything out of alignment, and did not spin it 180 degrees
Does it seem like this is the only possible cause? The shift rod is probably curved at the top? is spun out of alignment and hits at last exit point?
Thanks
Thanks
