I bought a used 17p prop for my '88 Glastron with Merc Black Max 150. I removed the old prop - which is a quicksilver 19p. I was going to reuse the hub but I don't think it will work. I can't remove the hub out of the old quicksilver prop at all. Does it have to be pressed out?? How can I tell if it will work with my new prop or not? The new quicksilver prop ad said it requires a flo-torq ii hub. Both props look identical except for the new one has a small circular lip at the rear of the hub area in the middle of the prop and the old one does not. It is completely flat. I attached a picture. The old prop is on the left and the new one on the right. Any info would be greatly appreciated. This is the first time I've ever done this before. Thanks in advance-
