Re: Can't Re-attach Outdrive the last .10"
Yes, I greased the new O-rings and the shaft spline. The shift lever is full forward, the shift channel piece on the drive shaft housing is aligned properly.<br /><br /> You know, the 2nd shaft O-ring should be just trying to go into the gimbal bearing opening about now, right? Maybe that is the sticking point. (I did not replace the bearing)<br /><br /> There is one step in my book which makes no sense to me, "Move bell housing sift lever to the right (facing transom from inside the boat) until the shift lever coupler locating slot faces to the rear." I assume this somehow refers to the shifting lever/roller alignment with the shifting slide. I think it is ok, but I don't see anything on the inside to move.
