cant get water cover off
mikevi
1979 evinrude 35hp 35952a
trying to replace the water cover gasket and thermostat, all screws removed, but cover is not coming off, I would think not to pry it off, tried rubber malot
would a heat gun be useful? any other Ideas to free the cover? looks like it hasn't been off since 1979 when it was built.
oldcatamount
Re: cant get water cover off
Try using an old but strong putty knife like you would use a chisel. Start the blade between the cover and the block and tap it in with your mallot, move it over a lttle and do it again. Keep doing this all the way around the cover and you will break the old seal without putting any pressure on the cover or the block.
mikevi
great idea, that will work, guess I should use the gel seal II on the cover, thinking I should also replace the head gasket too, does the head gasket need the gel seal II also? , I'm reading also some use locktite 518 in place of evindudes gel seal
tashasdaddy
many new gaskets say no sealer. never seize on bolts is a good idea.
ezeke
Gel seal is an anaerobic sealer, metal to metal - used for crankcase halves. It's not appropriate at all for sealing gaskets. A good all-around gasket sealer is 3M 847.
mikevi
ok manual says no sealer on head gasket, but does say gasket sealing compound with gasket on the cover, is that the gel seal II / locktite 518?
ezeke
Loctite 518 is an anaerobic sealer, metal to metal - used for crankcase halves. It's not appropriate at all for sealing gaskets. A good all-around gasket sealer is 3M 847.
mikevi
the 3m 847 temp range is -40 to 180 deg F , wouldn't the 180deg f be too low? for the cover?
Haffiman
Another name for the Sealing compound by OMC is Loctite Aviation.
This from product specs:
Loctite ? Aviation Gasket Sealant
Loctite ? Aviation Gasket Sealant, slow-drying, non-hardening brushtop sealant approved for use in aviation as well as automotive applications. Temperature range -65 ?F to 400 ?F; resists gasoline, oil and grease.
ezeke
Three Bond 1211 is also popular.
