can't get up to speed
Itec01
Hi fellow boaters,<br /><br />I bought a 1959 Johnson seahorse 18HP.<br />It ran good for 20 min. and then started getting weaker and weaker. It now runs at about 40% of what it did.<br />I checked coils, plugs gapped at .030, carb compression points gapped at .020. Just am running out of things to do. Any suggestions would be appreciated. I have run out of things to try.<br /><br />I have a service manual on order, but the fish won't wait, haha. :mad:
boatca
Re: can't get up to speed
Had similar problem<br />Check yer Fuel tank lid If yours is old like mine there may be no pressure release valve and builds up vacuum in tank so starves Engine. loosen it.<br />Also Check your Fule line from tank to Motor if Bulb is getting wore or cracks. I replaced mine and works well now.<br /><br />Oh yeah forgot to mention sometimes when it bogs down the spark plug gets carbed up mine did and I pulled it and cleaned it was good...
Itec01
Thanks boatca,<br /> I'll try that fist thing.<br /> I'll let you know if it works
