jim dozier
- Jan 8, 2003
- 1,970
I have a 1987 DT85 Suzuki with oil injection. I replaced the oil hoses and oil filter for general maintenance. I bled the oil pump as per the Clymer manual. The oil rose in the small oil lines until it got past the check valves and there is an air space in the larger tube that comes out of the checkvalve and goes to the intake manifold. I had it out all day on 50:1 premix and the air bubble wouldn't go away. I even pulled off the tube on the water let it fill up and as soon as I put it back on it gathers an air space. What is the deal here. The level in the oil tank is going down but I don't recall if there was an air bubble there before or not, the old tubes weren't very clear.
